i have just noticed on the scrollsaw i am thinking of buying, it says, power, single phase, what exactly does that mean, and can i just plug it in..
steveb
Since nobody has tried to answer this question, I'll dispense such meagre knowledge as I have!
Single phase machines can be run off domestic electricity supplies, whereas three phase machines require more power than a domestic supply can provide and are normally only used in industrial environments. You'll be able to just plug your saw straight into the household electricity, Steve.
I only know this because I was once involved in buying a heavy-duty enameling kiln for some craft workers in a community centre I used to run. I had to arrange the installation of a three phase electricity supply for them.
Gill
Steve, Gill is right in that most of your domestic electircity supply is single phase. I believe in England you use 100 Volt at 50 Hz single phase for your domestic supply. 3 phase is used for larger industiral motors with 200 volts or greater that is usually greater than 2 horsepower.
That is a good point and question...I always double check when looking through any want-ads to make sure it's not a 3phase tool. It's pretty common that I find a tool at a great price and then whammo...it's 3phase. I know you can get a 3 phase converter for your home/shop..but I don't know how that works or what it involves, I just stay away from that.
There are companies out there that sell all types of animal eyes.I have used them in the past and they really make a big difference in the
Will...
Ebony is a black wood though it is hard to find and very expensive. For round eyes l have taken pieces of dowel and rounded them on a sanding wheel. When I get the shape that I want I stain them with ebony stain.
Greetings from central Indiana.
Ask your questions, someone here will answer....
