Hi
Two question about cutting patterns
-Where you drill blade holes.
-And when inside cuts are close together.
When I drill holes for inside cuts . The back side of the wood is not a
clean hole the wood fractured. Would this be caused from to slow of a speed .
How to keep this from happening, have a backer board that you drill into.
when the inside holes are very close together pieces of the wood between the holes
chip out. The stock that I an using is Baltic Birch. Do you have any solutions to
keep this form happening.
Jim R
Jim R
