If your talking about cutting circular slices off the rod, a scroll saw is probably not the tool to use. If you have one a fine toothed miter saw/box is probably a better choice. If not a hacksaw should work also if your careful to keep it square. Either should give you uniform thicknesses (per slice) than a scroll saw.
Got to hospital at 5 and office didn’t open until 5:30. Could have slept to 4 instead of 3. Right knee replacement. Surgery was at 7, he was awake and up by 10:30, pt and out the door by 12. Not much to do today except take meds, and walk 10 minutes an hour. His knee has to bend back to 120 deg. Due...
This gallery has 2 photos.
