setting blade
  • setting blade
    What is the best way to set the blade at a true ninety
    degrees to table.
    Re: setting blade
    I use a small square (about 4' on a side).
      Re: setting blade
      I also agree that is the way I do it. Use a small machinist square and check both sides of the blade and you can't go wrong. JTTHECLOCKMAN
      John T.
        Re: setting blade
        If you don't have a little square, take a piece of scrap at least 3/4' thick and cut about 1/16' into the wood. You can do two things. Turn it over and try if it fits in the kerf or you can try if it fits in the back of the blade, without turning it over.
        Mike M
        SD Mike
          Re: setting blade
          Very good tip Mike! thanks
            Re: setting blade
            Thanks for the replys they are good tips that I will use.
