I have been cutting some oven shelf pulls today using 1/2" Poplar and want to try stack cutting at least 2 at a time which would be 1" thick or 1 1/2" if I tried 3. I would only try 2 at first. I have read about gluing tooth picks in the waste areas to hold together and my question is do I still use the same blade or would I want a more aggressive blade? Today I was using a FD TC#5 which is 13 TPI with a reverse tooth every 3rd tooth.
Stack cutting?
I don't find it necessary to use toothpicks, however that will work. I'd just tape the 2-3 pieces together. I'd move up to a #5 or #7 ultra reverse blade. Try the number 5 first it should work just fine."Still Montana Mike"
If the pattern is not very intricate maybe use a # 7. A #5 could do it but you need good tension on the blade, the blade should not move sideways more than 1/8". Have good speed but very low feed rate. Let the blade do the cutting they say.
I always staple it together,
FD Mike
The other Mike, you just was ahead of me. Thanks
Poplar is soft as far as I know it.Last edited by 3_M; 05-05-2012, 07:33 PM.SD Mike
I've done stacks that thick with woods much harder than poplar, so I think you'll be fine with a stack of two. Probably even three if you're careful. I second the FD UR# 7 recommendation. #9 if you're going to try three.
Reply to Bass Puzzleby Sandy OaksThank you for the nice comment....
Channel: Scroll Saw Puzzles
Today, 09:46 AM -
Reply to NWA Showcase 2023 Resultsby Sandy OaksCongrats on your beautiful entries....
Today, 09:46 AM -
Reply to Help with spray adhesiveby Scruffy DogUpdate: I found that a quick spray across the piece one time has been enough to adhere the pattern to the painters tape. It just takes a little practice. For example, the last piece I did had 4 strips of painters tape. I aimed at each one and did a quick spritz, like you do when using spray paint to...
Channel: Beginners Scroll Saw
Today, 08:01 AM -
Reply to NWA Showcase 2023 Resultsby RolfOur Club used to have a Buss trip from Long Island Every year to the show. That was a lot of fun! I always went with a pocket full of cash to buy wood and tools. Sadly we have not done it for many years now. The vendors can't make any money between travel, booth fees, and hotels.
Several...-
Today, 07:46 AM -
Reply to Mothers day flowersby Scruffy DogNice idea and nice job on them
Today, 07:41 AM -
