I have a problem with the blades won't turn when I turn my work to go another direction. I have tried running slow or fast it doesn't seem to make a difference. I hope someone has a suggestion for me. thanks David
Must be user error or lack of tension. push back on front of blade, the blade should only move about 1/8 inch back. When making a turn, spin the wood, do not push sideways to turn. These are the only things I can think of that would make a turn difficult. Also make sure the teeth point down not up..I've done this a few times...oops.
depends on what type of wood your cutting the size blade ext... the thinner the wood (and softer) the smaller and finer a blade you can use and in turn the tighter radius turns you can get, if your using #5s or 7s your turns will be wider unless you back cut the kerf a bit. HTH
Hi Dave, I have that problem too. and most the time it is. the tention. not tight enough. but also. my wood is warped some. just a little warp can give you fits. and also . not holding down my wood enough. ALSO. not to start a fight here. but some blades just do that. a skip tooth on 1/4 inch plywood is a good blade. I use a # 2 or even a 2/0. 24 or 26 tooth per inch. no matter if it is revers or not. but some blades just wont turn in the wood. belive it or not. try a cheeper blade. daaaaaaaaaaaaa i am in troubale now. but try it. also. check your blade for levale to the tabale. but mostly. its the blade. or warping, or tention. hope this helps. Evie Oh ya. sometimes slower is good. but then try a faster speed, but move your wood slow. remmber the blade only goes up and down. you move the wood. you can back up some befor a turn. then do your turn. also. if your going fast. when you come to your turn. stop. wait. and let the blade catch up. you'll be surprised how much you are pushing. relax your grip on the wood. and make sure your wood is not pused to the side.
The last time I visited with Denny Winter 2020, I had an opportunity to try out the PEGA Saw that Denny has set up in his store. I was extremely impressed with the saw performance. It will be the saw that replaces my EX21 when I need a replacement. When I visite Denny I was considering purchasing it...
When I worked retail, we would have products plainly labeled "One rebate per address". And people would go ballistic six weeks later when their claims for three or four got shot down.
Can't imagine if it had been in small print like the ads of today.
First time posting.
I have a Pegas Scroll Saw that is almost 2 years old.
I saw about 1-2 hours a night right now and the speed will slow down and speed up on its own.
Sometimes it will run full speed for a week and then switch to slow for a week.
Any ideas on what might be causing...
That is the one store I physically get sick as soon as I walk in. The odor of rubber is overwhelming and I’m good for 3 minutes before I have to leave. Sure glad other stores aren’t like that. Hmmm maybe my bank balance would be higher if they were.
I wonder if their effort to offer better quality products may have something to do with it. Seems like they want to market themselves as something more than just a cheap tool supplier. Maybe reducing the number of things eligible for the big discount coupons is part of a campaign to change their image....
