well i got my 3rd saw hegner, wow i to scared to use it tryed it once an i put the cut right in bin,,,, think i need to start again i did some ok cuts with the last saw , i need to practise so much,any tips would be great, thanks
3rd saw
Today, 09:21 AM -
Today, 09:06 AM -
by cwmageeCarole Your hole size was a concern when I purchased the Pegas Replacement Table for my EX21, because I had cut into the side of hole on the original table, The damage I did to the old table was due to the blade adjustments were not in the center of blade holders. So far that has not been an issue...
Today, 08:40 AM -
by RolfThat is an interesting point Carole. I have done some bevel cutting on the EX and can't say that I have experienced an increase in vibration or any problems with following the lines. I know when I cut one of your bowl designs on my Hawk I really had to concentrate on not pushing down hill....
Today, 07:28 AM -
by handibunnyJust a word of caution about the size of the blade hole. When I used a DeWalt years ago in the infamous community woodshop, and also with my more recent experiences with the Jet, if you do much bevel cutting at a steep angle, you will cut into the table. That's why inserts have the slot that can be...
Today, 06:21 AM -
