Sometimes my wood "burns" when I'm cutting. Any suggestions on how to prevent that from happening? Thanks.
Wood Burns
Some woods burn more easily than others, like cherry. I use clear packing tape over the pattern when cutting. It helps to lube the blade."All it Takes For the Forces of EVIL to Rule Is For Enough GOOD People To DO NOTHING!"
Hey Sue, to help prevent burning use either clear packing tape or blue masking tape. I like to apply the clear packing tape over the pattern. some folks apply the blue tape over the wood, then apply the pattern over the tape. The tape helps reduce friction which causes the wood to burn. It also helps the blade last longer.Dan in So.Ca.
I've also noticed it isn't so much the speed of the saw as it is the rate at which I'm feeding the wood into the blade. Slow down and enjoy your craft. It will benefit you on so many levels."Still Montana Mike"
This gallery has 2 photos.-
Today, 12:13 PM -
Reply to First Project - Stretching Catby Sandy OaksVery well done, especially for your first. I too like the added detail.
Today, 11:22 AM -
by RolfThe end result is beautiful I really like that Hummingbird design....
Today, 09:54 AM -
Reply to Help with spray adhesiveby RolfI have used all sorts of methods for putting on patterns. The only time I put a pattern directly on the wood is on Intarsia as the shaping process removes it. I only use blue tape under the pattern on very small projects.
I Use clear removable contact paper (shelf liner) on the wood and...-
Channel: Beginners Scroll Saw
Today, 09:51 AM -
Reply to Sanding and calibration disk.by RolfI agree about how it was advertised, but it is my own fault, I know better. Just for curiosity I may strip the paint off and see how true the plate is.
The good thing is that while I had my saw blade off I cleaned it sprayed Crud cutter on it let it sit then wiped it off with a skotchbright...-
Today, 09:42 AM -
