I have a Delta shopmaster and new to scrolling. I'm working on the "shalom" puzzle and keep breaking blades. I'm making it out of 3/4 " Walnut. Any suggestions on speed, blade, TENSION, ETC? tHANKS
Blades and speed
I would reccommend a blade at least a number 5 size.For a beginner, a blade without reverse teeth will work better for you,as the sawdust will clear the cut easier, making less friction then compared to a reverse tooth blade. Blade quality is probably a big issue, as your probably using the crappy blades supplied with the saw.Even still, walnut isnt THAT hard, you should be able to do it. On 3/4 thick, you can run the saw fullspeed, but just run it at the speed you feel most comfortable with.ith experience, you can speed it up without even thinkin about it. As for tension, I always say go as tight as you think, then a little more. To tight of a blade isnt really an issue, but to loose a blade, and you have all sorts of troubles.Also, be sure to only steer the wood with the saw running to avoid twisting the blade.
Relax, take your time, and have fun with it. And remember, its just a piece of wood until you are happy with the cutting, if it doesnt turn out as expected, grab another piece and try it again, because you CAN do it! DaleDale w/ yella saws
When I first started, I broke a lot of blades. I remember thinking "This was a 5 blade project". Well, now days I rarely break blades, and they are mostly because I bent them while inserting them in the holes.
Keep the blade as tight as you can. If you notice the blade doesn't cut very well, time for a new one. They can dull quickly. Also, if you notice that the direction of feed changes on a blade, time for a new one. this can be caused by several things, but I seem to do it when I start turning too quickly or have side pressure on the blade.
As for speed, cut what you are comfortable with. If the blade will cut it without forcing it, and you can follow the line, that is a good speed!Mark Abbett
DW788
I'm cutting 3/4 to 1 inch, and really hard woods at times. The only blades I own are #9 skip tooth. although i think i have a sample pack or two of assortments someplace, but I don't use them. I keep it pretty tight on the tension, shouldn't be able to push back on the blade more than 1/8 inch, and I run about 1/2 speed on the G4, maybe a little less. Those blades have alot of bite and I very rarely ever break one...I just use them till they are dull and toss them. Once and a while, but rare, when I'm cutting a tight turn on a very small but thick piece of wood I'll get some chatter/finger smashing fun.Jeff Powell
Try the forum search engine wording it a few different ways. Maybe something will ring a bell.
Today, 07:04 PM -
Reply to What do you think?You scored a working central vac for free....awesome!!
Today, 07:03 PM -
Reply to More toysThat's ingenious. Every kid will adore the ability to dump a load of legos for dad and mom to step on!...
Today, 07:00 PM -
Reply to Another Mid-Michigan ScrollerI agree---really nice pieces. Warm and sunny Arizona wishing you happy scrollsaw sharing with a great group on this forum.
Channel: Welcome Members
Today, 06:59 PM -
by DaveVanEssSorry for the mistake in the previous title. Shouldn't try to type when I have an ocular migraine! My website has a place to go donate.Today, 06:52 PM
