How often do you use a joiner/planer? Just wondering if this is a necessary part of my new workshop. Also, is it helpful to have a drill press with a laser to pinpoint where the drill will create the hole or is this unnecessary? Thanks.
just building my scrolling workshop
Re: just building my scrolling workshop
Like Hi-Ho, I don't use them often, but when you need them, you really need them (planer and jointer that is). As for the laser on the drill press - don't have one and have never missed it and am having a hard time visualizing how one would work on that particular tool. If it shoots straight down the bit would be in the way, if it comes in at an angel I suspect larger bits, particularly a forstner would get in the way. Don't really see the benefit anyway because if the position of the hole is critical I position the work before starting the drill press anyway. I guess if the machine you want has one get it, but I wouldn't let that feature influence my decision.
I don't use my joiner much but I use my planer a lot. I re-saw all my wood and I use the planer to get it to the thickness I want. I use an extra board 2x12 when planing down to 1/8'
MikeSD Mike
The top picture shows a nail that holds the board from sliding. That other picture shows the board so you can move the blades of the planer lower than without a board.
Mike MSD Mike
...Today, 07:31 PM -
by John Smiththanks Carole. I used the band saw with a 1/8" blade - not much different than the scroller but I have to use other methods to do the insides of the letters where the band saw can't reach. All the while, WISHING I had a scroll saw. and now, that I've got one, I'll be venturing back into dimensional...Yesterday, 07:21 PM
by handibunnyVery impressive work, John. I like the tooled leather look, the detailed calligraphy, and especially the rendition of the brushes and other tools that you use for your craft. It will be interesting to see how you incorporate the scroll saw into your work, and the opportunities it provides you.Yesterday, 06:31 PM
by John SmithThis is the finished project that I sort of "allured" to in my New Member post. The elements were cut out and attached individually in a "layered applique" fashion. Simple hand tools were used to add some "texture" to all of it. This is not wood or leather, it is HDU (High...Yesterday, 03:32 PM
