some of the projects i have done lately for christmas ornaments, i have found that with using plywood 1/8 and 1/4 inch the center plys of wood chip out , the cuts are fine but it is very noticeable is there certain blades, speed that would stop this
wood types and blades
Generally speaking the thinner the material being cut, the smaller the blade you want to use. Are you cutting one layer at time or stack cutting? What size & type of blade did you use?
Also, in your case, the plywood may be contributing to the problem as much as the blade. What kind of plywood are you using? I've routinely cut 1/8" baltic birch plywood and have had no problems with voids or chip out of the center plys.Homer : "Oh, and how is education supposed to make me feel smarter. Besides, every time I learn something new, it pushes some old stuff out of my brain."
Yer plywood sounds like the culprit and single layers is contributing. Upgrade to a quality plywood you will stop this problem."Still Montana Mike"
I use the Finnish birch plywood from Scroll Saw Patterns Plans Books & Blades for your projects - On Sale at Scroller Ltd. and the birch plywood from Sloans and have never run into problem with either.Mick, - Delta P-20
When I first started many centuries ago I used such items as old drawer bottoms, etc and discovered very rapidly it was a waste of time and effort. In fact, this Christmas I used some plywood from a cabinet shop and had the same problem. Wasted, no way to fix it...Chuck D
Jean De La Bruyere...
l
Reply to hegner 2"by MidMich324Just Wondering...
With the 22" inch one you get 4 more inches of depth of cut but do you also get a few more inches of table?-
Yesterday, 09:30 PM -
Reply to Spring Issueby will8989I had to fool around with copying and taping a pattern again today. This wasn’t as bad as the fish, but still a pain. I use rapid resizer. Scan a pattern, put in size I want and it prints it out. If more than one page, it numbers each page at the top and I tape them together. Had the fish pattern...
Channel: Publisher Feedback
Yesterday, 09:28 PM -
Channel: Scroll Saw Puzzles
Yesterday, 02:51 PM -
Reply to Spring IssueRolf
Yesterday, 01:48 PM -
Reply to YoraHome Laser w/CNC Engraver/Routerby theframerHi Linda, great find...I think.
Rick-
Yesterday, 12:05 PM -
