Hello, I'm a newbie. I've had my scroll saw for a couple of weeks now, and have really enjoyed it. I'm having a problem with my projects doing a lot of bouncing around (up and down) though. What am I doing wrong or what do I need to do? I have started out with some small things like star, heart, ghost, leaves, snowman. Any advice is appreciated.
Dab
Welcome to the forum.
You may want to check your blade and make sure that the teeth are facing down.
If the teeth are pointing up they will lift the wood off the table.
The hold down will stop wood from bouncing but most scrollers remove it shortly after they get their saws.
I find it is more important to apply a downward pressure to the wood than it is to push the wood through the blade. After awhile you will get a feel for just how much pressure to apply, both in the downward motion and then with pressing it to the blade.
Hope this helps, CarlCAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
Dab
Thank so much for your quick reply. I did put the hold down part on my saw, and it does help. My blade teeth are facing down. I have cut some things with little problem with bouncing, but some things, even going very slowly, seem to bounce a lot. Could it be a difference in the type of wood? Thanks again for you help.
Chatter
What you are experiencing is called "chatter". I think all of us had that problem to some extent when we first started scrolling. I still do occasionally if the wood has a little warp and isn't laying flat on the table surface or when cutting a tight radius with an aggressive (higher numbered) blade. Just keep practicing with simple cuts and turns and you'll soon find that the problem will go away. Welcome to the group!!!!If it don't fit, don't force it....get a bigger hammer!!
Is your saw Bolted down securely to the table? It should be and a pad of carpet or rubbr mat under it will help too. Also you may have your speed up to high. If you are cutting in a carpeted room you need to put y0our table on solid plywood - the thicker the better -- These are just a few of the tips I learned.
Sharon
PS Welcome to the forum
Welcome to the group Diane
You've definately found the right group to ask questions of . I have learned a ton here, and continue to make progress
....enjoy...~Robert~
DW788 and Hawk 226
Hi Diane
Rather than cutting out small objects, you might enjoy more success if you cut larger ones. The extra weight of the wood will work against any tendency for the blade to catch and lift your workpiece.
Dbonner
Thanks so much for the welcome. I am collecting tons of patterns. I really want to make some yard art stuff. I haven't tried any large items yet. I do have a jigsaw also, and I know I will have to cut larger patterns using the jigsaw. I'm not too familiar with the jigsaw yet either. Thanks for your help.
Diane
Reply to Who has Been Vaccinated ?by meflickI’m too young yet
don’t meet other guidelines. We are still 75 and over or health care workers I believe. My husband is in health care, so he has now gotten both of his shots. At this rate, I figure I will be doing good if I get sometime this summer.
Glad hubby got his, figure he was my biggest...
Today, 09:33 PM -
Reply to Who has Been Vaccinated ?by Jim McDonaldWaiting on Indiana to open the 65 yo group.
Today, 08:48 PM -
Reply to More toysby will8989You will bring a smile to the face of whoever gets these....
Today, 08:39 PM -
Reply to Who has Been Vaccinated ?by will8989Our appt is next week, I think. We are going to another county as ours doesn’t have enough. So they say. First one was cancelled for 2/1 as they had to make sure they had enough for the 2nd shot. Applied the next day and got the same appointment they cancelled. Go figure.
Today, 08:37 PM -
Reply to Who has Been Vaccinated ?by Jim FinnMy wife and I got our first shot a week ago.
Today, 06:55 PM -
