AMT replacement blades
  • AMT replacement blades
    I have an old AMT 15" scroll saw and have been unable to find a suitable blade that fits the machine. I don't have a users manual or Model Number. The blade arm has a plate that says 'Assembled blade range 5-7/8" to 6-1/8"'
    I have tried to fit a 5" OLSON pinned end #41101 but it doesn't fit the top adapter.
    Any suggestions on what size blade will fit this machine, and where can I buy it?
    Thanks!
    They carry 6" blades here just scroll down the page and you will find them. Scroll Saw Blades
    Tim
      Thanks Tim - I assume the non-pinned ends is what I want. I appreciate your help.
      RC
        RC
        I'm not sure what blades your saw uses but the non-pinned blades allow you to do more detail because you drill a smaller hole to fit the blade through.
        If you need adapters to go from pinned to non-pinned check out Scroll Saw Retrofit Items
        Tim
