inaccurate measurements on roman cath. clock pattern
  • inaccurate measurements on roman cath. clock pattern
    hey guys....has anyone here noticed any measurements that are off with this type of pattern....lm currently building one an for some reason a panel or two has come out shorter than others....I've always cut on the line......pattern has been copied....but I dont think that affects it.....thanks for the help
    I recently had a 6" ruler that came with a little desk box organizer and it was not accurate. I tried measuring something with it and it didn't come out right, I took a tape and sure enough it was off almost an 8th of an inch so it went in the trash.
      thanks for the reply.....as you might know.....glue was dry when I discovered the height difference.....lucky for me I used hot glue...so I just put my little pencil torch to it an off it came
        Not all copy machines or scanners do exact 100% copies either always double check. You can also use a heat gun/hair dryer to loosen hot melt glue as well as a microwave oven in slow increments.
          Part and parcel why the old ammonia blue print copiers had such a long run.
          I've never regretted spending money on quality rules, scales, squares, and set up gauges. Nuthin' sucks quite as bad as getting to assembly and discovering that even after two more cuts, the part is still too short.
          Ron Paul
            Hello jreece
            Quite a while ago we realized that older photocopiers do err and the only way we have been able to minimise the error is to photocopy the whole pattern at one time on one machine and orient the patterns the same way at all times. Check the photocopies to the original to see that they are accurate. Another way to minimise the chance of error is to cut all the vertical walls of each floor or layer at the same time---That is , if the base is 4 inches high, cut all 3 pieces 4", meter the corners and check against the floor layout. If all fits, center the scrollwork pattern on the boards and do your cutting. If the next vertical wall is 9 1/8 inches tall, cut all 5 wall pieces 9 1/8 "---don't forget to cut any full height decoratives at the same time 9 1/8 ". Most times you can stack pile remembering to allow for right - left sides. You can easily stackpile 2 1/4 " pieces of wood or 2 3/8"pieces and 4 or more 1/8 " depending on the difficulty of the pattern. The Roman Cathedral has fairly large body pieces so you can cut them on your table saw or metre saw or a band saw for the small pieces. Keep all your fingers. Be careful. You will get a much better fit on these tools over a scrollsaw. Keep us posted and we like pics.
            Norman
              thanks for the info
              Originally posted by north wood clocks View Post
              Hello jreece
              Quite a while ago we realized that older photocopiers do err and the only way we have been able to minimise the error is to photocopy the whole pattern at one time on one machine and orient the patterns the same way at all times. Check the photocopies to the original to see that they are accurate. Another way to minimise the chance of error is to cut all the vertical walls of each floor or layr at the same time---That is , if the base is 4 inches high, cut all 3 pieces 4", meter the corners and check against the floor layout. If all fits, center the scrollwork pattern on the boards and do your cutting. If the next vertical wall is 9 1/8 inches tall, cut all 5 wall pieces 9 1/8 "---don't forget to cut any full height decoratives at the same time 9 1/8 ". Most times you can stack pile remembering to allow for right - left sides. You can easily stackpile 2 1/4 " pieces of wood or 2 3/8"pieces and 4 or more 1/8 " depending on the difficulty of the pattern. The Roman Cathedral has fairly large body pieces so you can cut them on your table saw or metre saw or a band saw for the small pieces. Keep all your fingers. Be careful. You will get a much better fit on these tools over a scrollsaw. Keep us posted and we like pics.
              Norman
              thanks norman..for the info.....as this is my first wildwood pattern...I've discovered how true the old adage of "measure twice...cut once" actually is
              • planeur
                Reply to My covid angel
                by planeur
                Rolf when you say taper from right to left, do you mean thinner near the body and thicker at the end of cloud as on the wing ?
                And on each cloud touching the body ?
                I had already sand some part , will show show soon!
                Thanks
                Yesterday, 09:22 PM
                Reply to Tough Decisions
                I did that with Creative Woodworks. But when Bruce's group had their monthly meetings and swaps, somehow or other the ones I didn't buy ended up here! I keep all my holiday ones separate. But I also look at other patterns and think how I can reuse it. But sometimes that is just too much for my brain...
                Yesterday, 12:27 PM
              • Don in Brooklin On
                by Don in Brooklin On
                Since I refuse to subscribe till they do something about the patterns in the pull out. They even made the DVD tough to print patterns.
                What I do is look at the index of the book on scrollsawer.com and if see something I might want to cut I go to Walmart and check out the book. If I like...
                Yesterday, 11:59 AM
              • Linda In Phoenix
                by Linda In Phoenix
                Absolutely everyone here has made valid points. That's part of what I've liked about this group.....different view points and different ideas. And we respect the diversity. You people rock!
                Yesterday, 11:24 AM
              • NC Scroller
                by NC Scroller
                I too miss Bob Duncan. I do not think anyone from FC has taken over that role at least on this forum. If they have I am not sure who. Like Betty, I owe a lot to FC and this forum. If it was not for them and this forum I would have probably turned my saw into a boat anchor years ago. Oh how I looked...
                Yesterday, 11:22 AM
