What is a good spray-adhesive to attach a pattern to the wood for scroll sawing? I see so many different types and brands on the market. TIA, Bob
spray-adhesive
I use 3m 45. Others like the 3m77 and some use duro. Some use elmers. Whatever you end up liking is the right one."Still Montana Mike"
I go for the 2nd best one. Cheap #1 being free but that's hard to find.Last edited by oily; 12-04-2011, 01:47 PM.May the wind at you back .....
Not be from Lunch.
Oily's Gallery
I've used several and the most appreciable difference, IMHO, is price. The Duro product is no longer available under that name. The equivalent is Loctite 100. I used some for the first time this weekend and it works fine. Anytime you are using a new brand that you aren't used to, spray it a little heavy. Better that it be harder to get off than to start lifting while you are cutting.Homer : "Oh, and how is education supposed to make me feel smarter. Besides, every time I learn something new, it pushes some old stuff out of my brain."
LOCTITE 13.5 Oz. Acetone Adhesive is not any good for fret cutting.
It might work for large cuttings, but when doing fret the patterns comes off when doing cuts that are close together.
LOCTITE just does NOT hold well, seems like the cutting loosens the pattern next to the cut. (I did the permanent bond method) will try the 3m next.
here is another thread.
The other John A. Nelsonjohnsworkshop.comsigpicI just follow the lines and make sawduston a Seyco ST-21 and a Yellow DW788
I was using the 77 and bought some Elmers because it was cheaper .... but it keeps coming loose from the blue tape so i am going back to the 3M77. It's been very aggravating to be in the middle of a cut and have the pattern come loose. A good tip is to have a glue stick handy and use that to re-apply if needed.Jerry
Life's funny if you laugh at it!
http://dedijerry.blogspot.com/
http://www.etsy.com/shop/DediWoodworks
I definitely am sold on the 3m 77. I tried glue sticks, didn't hold. I tried Elmer's spray adhesive, came loose while I was cutting. 3M 77 sticks! I also use blue painter's tape on the wood and glue the pattern on top of it.
A spray can lasts a long time.
Nancy in AZA clean house is a sign of a broken scroll saw!
I use 3m77 also, have no problems with it. Edward
Channel: Welcome Members
Yesterday, 08:08 PM -
Yesterday, 07:56 PM -
Yesterday, 05:38 PM -
Yesterday, 05:09 PM -
Yesterday, 04:51 PM -
