Hello,
Just a quick question. I got new FD blades. I have a reverse 12 mounted in the saw. I noticed that I wasn't getting any tension on the blade when I flipped the white plastic quick release lever back toward the saw.
Then I realized that if I pushed down slightly on the blade mount part (circled in red on the attached photo) when I put the blade into the top blade holder, and then flipped the white plastic lever toward the saw, I could achieve tension.
As you might recall from my earlier post, I have turned the tension knob at the back of the saw so much that I think it's all out of whack. I think I have that settled now, but I just want to make sure that I should be pushing slightly on the circled part when attaching the blade.
Thanks for your help.
NewDog - needing to learn some new tricks, obviously!
