Hi e1, thanks to you all I have the saw up and running. Cut my first piece of wood. It was a quarter inch thick very light colored plywood or some kind of light veneer with plywood center. When I started to cut it went like butter then an inch into it the blade wouldnt cut thru it like butter anymore. I had to kind of shove it thru. Not real hard but I did have to use a pretty good amount of pressure. Is this normal or am I not doing something right?
The tension of my blade seems right I get a ping when I pluck it and when I push it to the side there seems to b less than an 1/8 play.
