Axminster AWFS18 blade alignment
  • Axminster AWFS18 blade alignment
    Hi all,
    So my AWFS18 came yesterday, and Im very happy with it.
    I have 2 questions though,
    1.) I understand that you can adjust the cut length somehow, but im unsure how.
    2.) The blade is tilted forwards quite badly. Is there a special way to make it perfectly vertical? It makes the back of a cutout vary hugely to the front. I have set the blades using the jig at the side, making sure the blade is perfectly straight, but when I set the blades in the holder it looks way out.
    If I put the blade at the back of the bottom holder, and the front of the top holder, that helps... Is it a matter of taking the top blade holder off, and re-drilling the holes, or am I missing something?
    Cheers.
    Luke, It sounds like the table is out of whack front to back. If it's brand new give Axminster a call and explain what's wrong and they should tell you how to solve it or exchange it, they have a very good reputation for customer service.
    • handibunny
      by handibunny
      Today, 09:21 AM
    • Bill Wilson
      by Bill Wilson
      Today, 09:06 AM
      Carole Your hole size was a concern when I purchased the Pegas Replacement Table for my EX21, because I had cut into the side of hole on the original table, The damage I did to the old table was due to the blade adjustments were not in the center of blade holders. So far that has not been an issue...
      Today, 08:40 AM
      That is an interesting point Carole. I have done some bevel cutting on the EX and can't say that I have experienced an increase in vibration or any problems with following the lines. I know when I cut one of your bowl designs on my Hawk I really had to concentrate on not pushing down hill....
      Today, 07:28 AM
    • handibunny
      by handibunny
      Just a word of caution about the size of the blade hole. When I used a DeWalt years ago in the infamous community woodshop, and also with my more recent experiences with the Jet, if you do much bevel cutting at a steep angle, you will cut into the table. That's why inserts have the slot that can be...
      Today, 06:21 AM
