Help! Which scroll saw in the uk please?
Though not up to knowledge on all the scroll saws available, I can tell you to avoid Titan and Erbauer like the plague, as I have returned both of them as they are virtually unfit for purpose. Both were from Screwfix, however, there are a number of other models from other retailers which look very similar in build, which I would also avoid based on my experiences.
Perhaps the SIP 01928 may be fine for that price band, but as I havent tried this out, I am unable to say for sure that it will be any good.
Shame to say, Id love to be able to afford the higher end models myself too.
Hope this helps narrow down your search.
Hi. Like you I am in the UK. Please don't even consider getting an excalibur. The ones sold in the UK are rubbish and most that have been bought have been returned including the ex-21 that I had, in the States they seem to be made from better quality materials. You next best bet is the AWFS-18 from Axminster but it is double the money that you have available. There have been good reports on this saw. Everything else that is available in the UK is Chiwanese and what you would call entry level scroll saws. If you are pushed for cash then probably the SIP saw would fit the bill but make sure you can get quick release blade clamps. I consider variable speed essential as you may be cutting thin plywood up the thick hardwood. You need to have the saw bolted down on a firm bench or a stand. In your shoes I would look for a pre-owned AWFS-18, try e-bay, if you find one you need to see it running and maybe try it out first. When you get your saw get your blades from Mikes workshop, they are the best. Don't use the blades that come with a new saw, they are usually rubbish, If you need any more help or advice PM me. Hope this helps.
by Quartz43My wife and I got vaccinated this morning. I had worried that there would be long lines. But, the state of Indiana seems to have gotten it right. We went online 10 days ago and scheduled an bbc.co appointment. We got there as nd no line and went thru the check in, got our shots, waited 15 minutes...
Today, 12:08 PM -
Reply to More toysby theframerLooking great Jim. Can't imagine and little guy I know who would not want these. I may BORROW
your idea for my three nephews.
Thanks for sharing.
Rick-
Today, 11:58 AM -
Reply to More toysby Sandy OaksThose are way cute, Jim.
Today, 11:53 AM -
by Jim FinnThis is what I have been working on this week. Using lathe and scroll saw. about 7" long tanker. I have made 20 of each so far
Today, 11:03 AM -
by RolfThat's weird, on my Volume disk 5, in the index I have Aticle index, Issue PDF's, and pattern pullouts.
The pattern pullouts are broken up into 8-1/2 x 11 s
At he end of each issue is a copy of the entire pullout for that issue....-
Today, 09:39 AM -
