Another beginner question. I'm cutting sides of a box. Some areas have long straight runs and slow curves. Other areas have tiney detail with sharp turns. Some of these go into sharp details at one end of long straight runs.
Question: Do you change blades to match level of detail even if it is in the same cut area? Or do you use a small blade throughout if there is tiney details anywhere on the piece? It's bit of dilema on my akward blade change saw (dremel). Long cuts look a lot cleaner to me with wider blades. Is that simply lack of experience?
Thanks,
Regis
Thanks,
Regis
