Can anyone help? I've looked through the internet and even visited a Delta Supply and Repair Rep, to no avail. Any Ideas??
Source of saw blades for Delta 40-560 saw?
Blades are readily available in a wide variety of types, sizes, tooth configurations and manufacturers. Probably the two most popular are Flying Dutchman and Olson blades. Any standard scrollsaw blade will work in the Delta.
Links to the blade suppliers can be found over in the left margin of this page, under Scroll Saw Resources. Most folks will tell you that Mike's Woodshop is the best place for the Flying Dutchman blades and Sloan's Woodshop is a good source for Olson blades. Call either one of them and you will talk to a real person who can give you first hand advice on their blades and their service is excellent.Homer : "Oh, and how is education supposed to make me feel smarter. Besides, every time I learn something new, it pushes some old stuff out of my brain."
Hi Pete! Welcome to the forum! At Mike's workshop site, there is a chart to determine what type of blade works for the material you are cutting. Olson blades use a different numbering system, so, just google Olson scrollsaw blades. There you will find a chart for their blades. OR you can just ask questions right here. Whatever you do, avoid getting blades like Vermont American, or at Sears. Very poor quality, and you will get even more frustated learning to scroll!
Paul
by cwmageeI have the Pegas replacement table for my EX21. It was the best investment that I made. The best part is they eliminated the useless vacuum holes and reduced the size of the blade hole as well. Another benefit was the table stiffened the EX21 frame eliminating much of resonant vibration. It is a much...
Today, 09:45 PM -
Reply to Shawl pinsby KarlBThat's what I was wondering Betty: If these would work (larger) for hair?
Karl...-
Today, 04:47 PM -
Reply to Shawl pinsby RJwebWho said being bald isn’t a plus, RJ...
Today, 01:18 PM -
by will8989The perfect solution when I need a wider top on my Hegner. A magnetic sheet! I decided not to get the Pegas as the only reason was for the wider top and the top feed blade. After 19 years, my Hegner is still running like new and I couldn’t justify the expense. It was a “want” and not a “need”....
Today, 12:27 PM -
Reply to Shawl pinsby will8989Good idea Scott. Also, my daughter has long, curly hair. She twists it up and around and sticks a pencil in to hold it. I also stick a dowel in my hair when working and my hair gets in my way and I twist it up. The one in this picture would perfect for thick hair.
Today, 12:19 PM -
