I've been using the Scotch repositionable craft stick in the blue tube. It works great for me and no residue. I had used it when I did some chip carving and found it works good for scrolling. Thought I'd pass it along.
Attaching pattern to wood
Nice tip, thank you for taking the time to share it."Still Montana Mike"
I was using spray adhesive for a long time after I first started 25 years ago, until last summer. I occasionally still need to use it, on bigger patterns. But, I had problems with it not wanting to release after cut, requiring heat or mineral spirits. I also had problems when sawing, with parts of the pattern releasing while cutting, making the patterns flutter up and down with the blade. That makes staying on lines very difficult.
I now use Xyron 9" and 5" cold laminaters, with repositionable adhesive cartridges. This is a little more expensive, but the patterns work so good. They stay on while cutting, and release when finished. There is no muss, no fuss in getting your patterns ready to cut. It is a very nice solution to the gluing process. Of course, as stated, it does cost slightly more to us than spray adhesives or other glues. But, just in my opinion of course, it is well worth the final results.
I don't understand the fuss people make about putting on mineral spirits to remove a pattern. All you have to do is apply it with a paint brush, wait one minute and the entire pattern comes up in one shot. I then give the wood a careful wipe with a paper towel. Thats all there is to it. It's really not that big of a deal. Using painters tape under your pattern is nice, but that tape is not cheap. Between cutting, sanding, staining and finishing, removing the pattern with mineral spirits is the easiest part of the entire process.
I agree with sawdust. Blue Painters tape aint cheep. And a bottle of Minera spirits goes a long way. Just let dry before burning the fuzzies off the project.ouch...!!!
www.pajarostudiowns.com
Excalibur EX-21 fanaticOne of the Chosen few
www.xyron.com
This is not for everybody, but for me it is the only way. I am not trying to say it is the best for everybody or anybody else for that matter. Just my way of spreading the word on another option. Thanks. Paul
Originally posted by JoAnne View PostI like to use blue painters tape and attach the picture to that using the adhesive spray. When you are done just peel the tape off. Works for me
Originally posted by sawdust11703 View PostI don't understand the fuss people make about putting on mineral spirits to remove a pattern. All you have to do is apply it with a paint brush, wait one minute and the entire pattern comes up in one shot. I then give the wood a careful wipe with a paper towel. Thats all there is to it. It's really not that big of a deal. Using painters tape under your pattern is nice, but that tape is not cheap. Between cutting, sanding, staining and finishing, removing the pattern with mineral spirits is the easiest part of the entire process.
So - much easier to grab the glue stick and use that. If the pattern sticks, just moisten w/a damp rag. No muss, no smell....
T
Forester, sounds like you got some straightening up to do, lol. I don't find the odor of mineral spirits to be strong at all, plus they also sell a low odor brand. Also the brush I use for the mineral spirits is not used for anything else. When I'm done, I place it under the handle of the can so it doesn't get lost. An organized workshop is an efficient workshop. As far as glue sticks, I've used them for small pieces when doing intarsia. But for large sized patterns, I don't feel glue sticks are a good method. It's very hard to tell if you got the whole pattern covered and if there is enough glue on it. Nothing worse than the pattern lifting while cutting.
The blue tape under the pattern method is the best and quickest. However, blue tape is expensive and that's the big drawback. I sell alot of my items. So I do what I can to save on material costs as much as possible. As those of you who sell their stuff know, when you factor in time invested to make something, we are not making a lot of profit. Every dollar you can save counts, especially over the long run.
Today, 10:23 AM -
Today, 10:19 AM -
Today, 07:55 AM -
Yesterday, 08:15 PM -
Yesterday, 05:07 PM -
