As you all know we use 1/4" luan plywood for backing and shims for our intarsia projects. I bought mine in your standard 4x8 sheet at Lowe's and had them cut it down there into 3 sections for easy transport. I leaned it up against the wall at home and within a week it was terribly warped. Any ideas to keep it from doing this?? Or is it simply a poor grade ply. I am in Tennessee and I keep the humidity low in my house so I can't figure it out unless I have it cut into smaller sections and possibly lay something heavy on it until I need to use them. Suggestions are appreciated.
Keeping Luan Flat??? Ideas???
Luan is a very low grade ply, mainly used for door skins and floor under layment. always keep it flat. By leaning it against the wall it is always going to warp. You can lay it flat on a concrete floor and weigh it down. It will absorb moisture from the concrete and flatten out again."Still Montana Mike"
Thanks...Little light hearted....Hope I was able to help. I usually bring home my luan and pre-cut it to 9x12 or so. Then i can stack it for later use."Still Montana Mike"
I sandwich mine between 2 sheets of 1/2 in ply left over from redoing a roof on my shed. and lean the whole thing against the wall on stickers placed on the floor to prevent moisture from getting in. Seems to work.
Fredfret
Wichita Ks
Keeping plywood flat is always a challenge. I have a fairly small shop so storing plywood in large pieces is not practical. I do what has already been suggested. When I buy plywood I decide what I am apt to use it for and cut it to those dimensions and store it flat and weighted down until I use it.Stoney aka Al
This gettin old stuff ain't for sissies!
Reply to hegner 2"by dwssr2I have no idea what the measurements of the 18" table are, I can give measurements of the poly max and the 14"....
Today, 05:22 AM -
Reply to hegner 2"by MidMich324Just Wondering...
With the 22" inch one you get 4 more inches of depth of cut but do you also get a few more inches of table?-
Yesterday, 09:30 PM -
Reply to Spring Issueby will8989I had to fool around with copying and taping a pattern again today. This wasn’t as bad as the fish, but still a pain. I use rapid resizer. Scan a pattern, put in size I want and it prints it out. If more than one page, it numbers each page at the top and I tape them together. Had the fish pattern...
Channel: Publisher Feedback
Yesterday, 09:28 PM -
Channel: Scroll Saw Puzzles
Yesterday, 02:51 PM -
Reply to Spring IssueRolf
Yesterday, 01:48 PM -
