What is the trick to cutting curves without getting flat spots? Saw a post where he ask how to sand inside corners. Response was no need to sand, blade cuts smooth enough. I understand what he meant. I also have to sand to get the flat spots out. Thanks, Dana
Cutting curves ?
One word.
Practice. Not being a smart aleck, it is technique and you will need to practice using your pivot finger and keeping a smooth line of cutting. Do not stop your movement of the work piece as this will result in a flat spot every time."Still Montana Mike"
Dana, when cutting a curve or a straight line, if you start to go off the line come back to it gradually rather than abruptly. You will then most likely go off the other side. Like Dan and Mike said, practice. The more you cut the better you get. Try to relax while cutting also. Tight fingers, wrists, arms and shoulders make crooked cuts. Whenever I don't cut for a couple weeks I will make a few practice cuts on a scrap piece to get back in the groove. Go into "Word" if you have it on your computer. Print out a font, glue the entire alphabet to a piece of wood and cut all the letters. By the time you get to Z you will be an expert. Good luck.Mick, - Delta P-20
As the others said, practice, practice. However there is another trick if you are cutting an outside circle. Don't cut on the line, but outside of it, then you can use your sander to sand just to the line. Hpe this is of some help.
Jack
In my best Jack Benny voice:
"How do you get to Carnegie Hall?"
"Practice, practice, practice."
And then be ready to still some flat spots. But as time goes by, the flat spots will get smaller, but your eye will notice them more!Jim
I agree with the practice and slow but steady idea. The more the better. My trick is to cut with the right (the more aggressive side of most blades) side of the blade in the waste area and to keep the left side just outside the line. A bit of sanding removes any high spots and smooths out the curve.
George
delta 650, hawk G426
Steve Good has made several instructional videos...including one on cutting curves...you can check them out at Scroll Saw School Index. I hope they help a bit...I know they helped me.
Can't add a thing. Glad some of the OLD pro's stepped in. LOLMay the wind at you back .....
Not be from Lunch.
Oily's Gallery
Originally posted by littlepig View PostWhat is the trick to cutting curves without getting flat spots? Saw a post where he ask how to sand inside corners. Response was no need to sand, blade cuts smooth enough. I understand what he meant. I also have to sand to get the flat spots out. Thanks, Dana
When you drive a car have you noticed that if you look at the horizon you drive in a nice smooth line but if you look at the road right in front of the car you tend to be all over the road? Same thing when cutting. Don't look at the line right next to the blade. Look a little farther down the line you are cutting.
T
by jim_mexHi folks - Since I retired over 2 years back I seem to have been busier than I ever could have imagined despite having two accidents involving arm fractures over the past 9 months but this is not the reason I've been absent from this forum.
In mid April of this year I took possession of...-
Today, 06:38 PM -
by Jim McDonaldBeen working off and on on this batch for a while. Locally, all I can get in square stock is poplar, so I dunked some of these in various stains. (It would be somewhere between 80 and 100 mile round trip to find any other specie of wood in sufficient size.)
Birds are also cut from poplar...Today, 04:43 PM -
Reply to God deal or not for CPU?by Quartz43I hate Norton with the constant pop ups and emails. It becomes a pain. Does a good job but very annoying.
Today, 01:00 PM -
Reply to God deal or not for CPU?by will8989Got rid of McAfee never liked it. I’ve used Norton forever and it has worked for me. Will look at windows defended. Never heard of it. Still rolling along....
08-06-2022, 10:09 PM -
