what exactly is a floaty
  • what exactly is a floaty
    I have been trying to make some patterns lately and I keep seeing ref. to floatys, what exactly is a floaty and what is its function? TIA
    Daryl,
    A "floaty" in a pattern is a piece of the pattern that would fall through/out if it was cut.
    For example, draw a circle on a piece of paper. Now think of the paper as your overall fretwork project and you want to cut out that circle line, the inside of the circle would be a floaty, and fall out of the picture. So to correct that, re draw that circle as an arc that is 3/4 the circle. Now if you were to cut the line you just drew, it would be held in place by the rest of the background, in this case being the paper.
    When it comes to pattern design, you don't want floaters.
    Hopefully this make sense, I admit I haven't slept much and the phrasing may be a little off.
    Take care
    Toni
      ok Toni lets see if I understand this right as I am looking at the pattern it seems the whole left hand with the door thing is a potentail floaty because it has no joinings to the back ground? right? and apparently part of the garment back also so from what your saying they would just fall off the background completly
        Daryl,
        Yes that's correct. I am looking at the picture you posted in the other thread under pattern design. There are some parts on the back of her shirt that would fall out and on the other areas we talked about.
        The door hanger has some.
        Look at her shoulder. You have a black line/cut line and it doesn't complete the arc. This works to hold her arm in with the background along with the opening at the bottom of the portrait.
        I've attached a quick note, not sure I have them all at a quick glance but hopefully it helps you find the floaters and work out the pattern.
        Take care
        Toni
          If the portrait is to be mounted on a backing, I don't think "floaties" are always a bad thing. They can add a lot to the look of the project. If you save the cut out pieces you can reassemble the picture and get the floaties in the right spot.
          EarlinJax
            Toni thank you so very very much I totaly understand now, all need to do is add a few more breaks in the lines or remove some lines totally the one on her back thanks again Toni
              I worked on it some more I removed the one line on the back fixed both eyes and added breaks in the door knob plaque, good think I have tons of Patience otherwise I would be bonkers heehehehe
                By George I think he's got it!
                Great work Daryl!
                  Tip for finding floaties
                  Here's a quick tip to check for floaties before printing your patterns. Regardless of the program you are using to make your pattern there will be a paint bucket tool (or something similar). Select this tool along with a fill color different than your pattern lines (I like using black lines and a red fill color) and click anywhere on the background. Any floaties left in the pattern will remain white allowing you to easily spot and fix them.
                  Keep scrolling!
                  DeWalt DW788 & Dremel 1680
                    Thanks for answering a questions I didn't know I needed to ask.
                    This will hopefully fix a few problems I've been having.
                    Kelly
                      Glad to be able to help.
                      Look forward to seeing the portrait when it's all cut.
                      Take care
                      Toni
                        Kelly, are you working on patterns too? Portrait? Going to show us??
                        Take care
                        Toni
                          Actually, the polar bear I cut out last week was from a picture that Carl had sent me.
                          It had the words Polar Bear written under with a paw print inside the O but I couldn't for the life of me figure out how to do it so that I could cut out the O and keep the paw print in the center. So instead, I just left the whole word out and only cut out the polar bear.
                          It's the little things that confuse me
                          Kelly
                            Originally posted by Dusty Buffalo
                            ....It's the little things that confuse me
                            First I would like to say what a wonderful job you did on the polar bear.
                            It is a perfect case of less is more.
                            As for the little things, they always have a way of sorting themselves out.
                            It is the big things that get overwhelming
                            I do not remember how the paw print was in the picture but I have done a few wolf plaques in the past where I tilted my saw at 3 or 5 degrees and cut the paw print on the bevel. The paw print then dropped down slightly in the plaque and it looks like a real paw print in the snow.
                            I sure wish I could take credit for this idea but..... Oh well it looks really cool when it is done.
                            P.S. you could try that with Neal's idea
                              man...I thought a floaty was that stuff down at the bottom of my glass of water, which I refuse to drink btw.
                              Jeff Powell
                              • Bill Wilson
                                Reply to Harbor Fraught
                                by Bill Wilson
                                I wonder if their effort to offer better quality products may have something to do with it. Seems like they want to market themselves as something more than just a cheap tool supplier. Maybe reducing the number of things eligible for the big discount coupons is part of a campaign to change their image....
                                Today, 02:41 PM
                              • Bill Wilson
                                by Bill Wilson
                                I've owned both tilting table and tilting head saws. My current saw is an EX-21 (pre-Chinese made version) with the tilting head. I have to say that for beveled cuts, I much prefer the EX over my previous tilting table saws (Craftsman and Dewalt). I think a lot of it is the rack & pinion angle...
                                Today, 02:06 PM
                              • hotshot
                                Harbor Fraught
                                by hotshot
                                Just a random annoyance . . . . Anyone get frustrated by the Harbor Freight ads that say no exclusions, then you see the details and see "for items under $20", or worse yet, in super small print, "Can not be used for: Atlas, Bauer, Central Machinery, CoverPro, Hercules, Predator, compressors,...
                                Today, 01:04 PM
                              • hotshot
                                Reply to Cutting Air
                                by hotshot
                                about an inch and a half.
                                High ceilings make a house look super elegant. You have the option of doing some cool interior doors that are not possible with 8 foot ceilings. A lot of the large very old houses in my area have those....
                                Today, 12:46 PM
                              • hotshot
                                by hotshot
                                And no annoying dust collection holes, for little pieces to catch on, right?
                                Since tilt arm style saws are my personal favorite . . . I can criticize it right? I hate the freaking dust collection mechanism on my King, and prefer the table on the older Green EX that didn't have that....
                                Today, 11:22 AM
