When I view some of the work shown in albums, I have wondered how some of the lines (for example skin creases) are made. I assume some of them are very fine cuts with a small blade, but are some of the markings made with wood burning?
Dale, I have used a wood burner to do some of the fine lines in a picture if I think it will weaken the wood too much to cut it. I believe it adds to the picture also. I have just a cheap wood burner that I can place different tips onto. I always practice on a scrap to make sure I have the tip I want.
Mick P-20
Mick, - Delta P-20
Mick when you burn those fine lines into your wood do you burn right throught the pattern or do it freehand ? and when you do your finish how well does the burning show? TIA
Daryl, DON'T burn through the pattern!! If it is something you don't feel comfortable doing freehand, lightly pencil it in, or rub pencil lead all over the back of your pattern in that area and use it like graphite paper to transfer the lines (lightly) to the wood. Don't use carbon paper either (do you have to ask how I know??) 'cause it will leave a greasy residue on the wood that will just get nastier as you try to remove it. If you do a nice burn, it will show through most finishes just fine. Burning after finishing would release some nasty fumes you wouldn't like (don't ask!!) Sandy
Thanks, Dale
Hi Dale. I think your question, was how was the little lines creatied. like skin creases. well, it is called vaining. and what i do is. I drill the smallest hole i can at the begging or a v joint. and use a flat blade to cut the line. then i follow up with a spirale blade to try to widen the kerf, so as to try to hide the drilled hole. but sometimes , ok most the time, you just can't hide that dang old drilled hole. if you have a pin blade this would be shuch a big old hole to begin with , so you could do a woodburnig thing. not something i am good at, at all. on this picture, i just drilled a small hole. then inserted the smallest blade that fit the hole then cut away. it looks bad at the beggining. but after all is done. it looks great. your friend Evie
Thanks all for the response. Sandi, you sound like you have had some experiences that you will help me and others avoid. Thanks.
Evie, I love that pattern with the horse and buggy and you have done such a nice job . Is that a lid on a box or ? (hinges) I love the backing too. Would you consider sharing that pattern or tell me where I can get it. I am a retired Family Doctor and that sure looks like it could be an old time M.D. going to make a house call . I'm probably not good enough yet, but I would love to try it before too long. Please either respond here or a PM
Thanks, Dale
Thanks, Dale
DW788
Hi Dale. yes that is a doctor going to help someone. but in a omish way. I got this pattern from. the book. Scroll Saw Fretwork Patterns. buy Ptrick Spielman & Jams Reidle. page 26 and its called horse_and_carriage silhouette pattern. and no that was not a lid. i made some photo albums that year for are kids, for xmas. I would be glad to shar how i did it with you. thanks for the complement. your friend Evie
Hi I tryed to load this veining on my last visit but here goes again. this is also a pattern from the book. ScrollSaw Fretwork Patterns. just a close up of the veining. and how it dont' matter in the end result. your friend Evie
This is all done with veining. I havent tried woodburning yet, but it would be fun as well. Dale
EDIT Well, my picture didnt pop on here , but it was sposed to be the indian feather seen in my gallery photos.
edit again.... now the photo shows up! Lol
First of all friend Evie, for the pattern info. and a big AMEN to what Evie said about your work Dale. Since that is a good example of "veining", I can see that I'd better do some reading and learn about that procedure. I sure don't have any idea where I should begin. I've got Patrick Spielman's Handbook, so hopefully it will be discussed there.
I plan to try a portrait tomorrow. The pattern is one that Robert aka Sawduster was kind enough to do for me.
Everyone in this "family" are so great to help one another, especially we beginners.
This gallery has 2 photos.
