Hello. I am a student in a wood shop class. The project we are doing requires us to cut intricate curves on the top of a shelf. I have used a scroll saw before but I have made several mistakes on my last project with it. :-[ The teacher requires us to use the scroll saw to cut the curves, so I am wondering if any one has any useful tips on how to cut the curves out nice. Please. :'( I really love my wood shop class and I would like to pass it.
Tips For Using A Scroll Saw
Re: Tips For Using A Scroll Saw
I am no expert with a scroll saw, but I suggest you drill more holes to realign the blade in and cut to the outside of the line.
Most important, take your time and remember you can back up a little and restart a cut.
Without knowing your exact problems, it is difficult to suggest a correct course of action.
Add to what Rick has said, just don't rush the process. If you feed slowlyy ou won't have to make as many 'corrections' as you go along, resulting in a much smoother kerf. That requires less sanding when finishing and gives a more consistant cut. Might help to make a few practice pieces to get the feel of the saw, and how you react to the cutting process. Most woodworkers and carvers that I know work a few practice pices on almost everything they do at least until they get comfortable with a particular tool or process.
Al
The only thing I can add is to leave the line on the wood when you cut and use a rasp to smooth out the wood. Good lighting and feed the wood to the blade very slow. If you're having a problem making tight turns, turn off the saw, get a file and smooth off the edges of the back of the blade, this will help keep the blade from snagging your work!My Site Missouri Ozarks
Don't dispare, the problem is one of experience. In a classroom setting, you have very limited exposure to frequent use of the saw. Consequently, when it is your turn to use the machine, you tend to be a little nervous. Most of what experienced woodworkers do is from habbit developed over time. I would suggest practicing with a piece of scrap wood prior to working on your project, each time you use the machine. Good luck.
Ric
A couple more hints: Use good blades and a #3 or #5 is probably easiest to use. If you are cutting 3/4' oak or simular, you might want to go up to a #7, and remember to feed slow. Tension the blade till it 'sings' when you pluck it. The tighter the better. A scroll saw doesn't cut 'Square with the world.' Because there is set to the teeth on one side of the blade only, it cuts a few degrees to one side of straight ahead.
Most scrollers use a fine line and 'Saw down the center of the line.' It's easier to cut on a line than keep a fixed distance from it. When you get off the line, just 're-aim' and get back on the line slowly. Aim the blade towards a point about 1/16' ahead of the blade. Also easier said than done.
When you take the pattern off, no one but you will know if you followed the line or not. Remember to feed slow, a good smooth cut with little or no sanding is what you want, not speed . Very little fretwork is ever sanded. If you want to cut fast, borrow a saw from Colin.
Have Fun Ken
Reply to Question about tilting head sawsby cwmageeThe last time I visited with Denny Winter 2020, I had an opportunity to try out the PEGA Saw that Denny has set up in his store. I was extremely impressed with the saw performance. It will be the saw that replaces my EX21 when I need a replacement. When I visite Denny I was considering purchasing it...
Yesterday, 10:24 PM -
Reply to Harbor Fraughtby Jim McDonaldWhen I worked retail, we would have products plainly labeled "One rebate per address". And people would go ballistic six weeks later when their claims for three or four got shot down.
Can't imagine if it had been in small print like the ads of today.-
Yesterday, 09:46 PM -
by mccrookstonFirst time posting.
I have a Pegas Scroll Saw that is almost 2 years old.
I saw about 1-2 hours a night right now and the speed will slow down and speed up on its own.
Sometimes it will run full speed for a week and then switch to slow for a week.
Any ideas on what might be causing...-
Yesterday, 06:01 PM -
Reply to Harbor Fraughtby will8989That is the one store I physically get sick as soon as I walk in. The odor of rubber is overwhelming and I’m good for 3 minutes before I have to leave. Sure glad other stores aren’t like that. Hmmm maybe my bank balance would be higher if they were.
Yesterday, 03:24 PM -
Reply to Harbor Fraughtby Bill WilsonI wonder if their effort to offer better quality products may have something to do with it. Seems like they want to market themselves as something more than just a cheap tool supplier. Maybe reducing the number of things eligible for the big discount coupons is part of a campaign to change their image....
Yesterday, 02:41 PM -
