howdy all
While i was playing with my bird project i tried using all my old soldering irons for wood burning, had about 7 of them. Heres the results. The power rating on most of them were worn away. A few never got hot enough to to anything, the only way i could make a dent in the wood was to hit it with a hammer....lol
Most of them got hot enough to burn the wood. Im sure it was my technique, on first contact with wood it burned a dot, id try to burn a line, but ended up with dot, line,dot line etc. Either i moved too slow or too fast.
The tips on them were ...well used.... If you have any laying around give it a try.
To my supprise my sears solding gun(130watt), the one you pull trigger and a light turns on was the best. It would draw lines straight and curved, just like a pencil, and do all sorts of impressions. It was just awkward to use.
I went to AC Moore store and picked up a 25w woodburning kit with a few tips, im learning on that. Im thinking if my solder gun is easier to burn designs in wood then mabey i need to look into some of the bigger wattage units.
Not sure if this helped anyone but thought id share the info.
.......the end
.......the end
