Welcome Faith. So you just got your new saw. how fun. like Dale said. you do need to drill some holes in your wood first. to put the blade through. do you have derictions on anything?? maybe you just wont to see what the saw can do. well , first remove the wood from your tabale top. ok. follow the directions.(hopefully you have it all put together. and pluged in)follow diritions, on how to put the blade in. the bummer is you have to keep going back to the derictions on how to connect them. they might tell you how to tention the blade too. hopefully. then put a piece of wood on the tabale top.( thats the little flat thing , looking like a alumiuminom flat thing.. )in front. not behind the blade. and try cutting a line. did they tell you how to put the blade in. the teeth should point down. towards the floor. and they should face you. if you are setting in front of the saw. then sweetie. just start cutting. you don't have to worry about cutting your self. as long as you hands are not infront of the teeth. just make a cut or two. you don't have to fallow anything. just cut. see if you can back up. into the cut. ok now go for it. it gets easyer. I have been there. buy your self a book or two . on how toos and what nots. I love the spielmon books my self. they got me started. and they will teach you how to use your saw. we all started there. your friend Evie
Pratice Inserting The Blade A Few Times Without The Wood. It's A Seek And Find Kind Of Thing With Your Fingers At First. It Wiil Feel Awkard At First But It Dosent Take Long To Get The Hang Of It. Just Keep Trying, Once You Get It You Are Going To Love Scrolling !!! Rain Man
I got so angry I just wanted to kick the saw but after my childish temper tantrim was over and my husband stoped laughing (because of the piece of wood flying by his head he stoped) I finally got a handle on how to get the blade on with the wood there. Mine hooks at the bottom and then at the top. but I got it Now my saw takes pinned blades and the pattern I want to do has little cuts that that are smaller than my blade ends what do I do?
Don't kick the saw ! They've been known to fight back and break toes.
As you're no doubt aware, there are two types of blades available for scrollsaws - those with pins and those without. Most of us tend to use blades which don't have the pins because it means we don't have to drill large holes for piercing work - it sounds as if the pattern you're trying to use is designed for these flat blades.
What sort of saw do you have? It may be possible to fit an adapter which will convert your saw to take flat blades; you can buy them online from Frank Pozsgai.
Alternatively, I've seen it suggested that you can take a flat blade, drill holes in the top and bottom, and then insert safety pins to secure the blade in place. I must say that I've never tried this myself and since my blades rarely last longer than half an hour, I'd be unwilling to experiment.
Gill (who's feeling light-headed after writing something that's actually related to scrolling for once)
...Alternatively, I've seen it suggested that you can take a flat blade, drill holes in the top and bottom, and then insert safety pins to secure the blade in place. I must say that I've never tried this myself and since my blades rarely last longer than half an hour, I'd be unwilling to experiment.
If you take a pair of pliers you can pull the pin from the top if the blade. Leave the bottom pin attached.
Put a safety pin in the hole in the top of the blade after you have threaded the blade through the wood.
I hope youve got it figured out, and are out there making all sorts of sawdust! Save your first cutting , put it away for 1 year, then pull it out as a comparison piece. Take your time, and have fun, and please, dont kick the saw! And, on behalf of your husband..... only use softwoods if your going to be throwing the pieces!!!! Welcome to scrolling! Dale
🍷🍷MD is a cluster mess. Getting the vaccine is fast. Getting the appointment is another story altogether. The county executive makes the rules for their own county. State says 65+ the jerk that runs this county says no, 75+ then puts a whole bunch of people on a priority list. But, there are state...
I have used some spirals on portrait style cuttings and while I don't hate them, I find my concentration level goes way up with them. If I am thinking 1/8" ahead with a flat blade, my interest seems to be about 1/32" with spirals.
Also, I am not a fan of the jagged edges inside the...
