Olson has a blade specifically for metal and it works rather well in my humble opinion. Remember to use a cardboard backing when cutting metal,- don't want any damage to happen to that dewalt table and it helps reduce the noise.
I have used FDM blades to cut aluminum ,pvc,wood,acrylic with just a #7 or #9 two way--two way becaause thats all I have besides spiral-- but I know there are blades made espically for cutting heavier metals --I have even cut diamond design aluminum with them and had no problems..you can ask Mike ( 3M) and he will know what you need--just send him a e-mail tho cause he doesn't answer the private messages here . but I think it is a metal blade from just about any company--just go with what brand you like
Update at 13 April – Its been almost a month since my last post and my shop extension is progressing albeit slowly largely due to me nibbling at it on a regular basis rather than sticking with it and going full blast to get it finished.
The outside of the extension is almost finished apart...
