Sorry, I'm ignorant. What is an easy-lift, and why do I need one? Where do I find one?
What is an easy-lift?
It's a spring loaded upper arm holder-upper for a DeWalt 788 scrollsaw.
Check out www.jimdandy.com for the info.
Wildwood designs sells them too!
I use one and it works great!Fred
EZ lift
I also bought an easy lift form Jim Dandy and really like it. It's a lot better than putting a block of wood under the arm while changing blades or top feeding. I would recommend getting for yourself (saw).
Oh, yea when you call you get a real person (don't know if it is Mr. Jim or Mr. Dandy) to talk to. So you won't have to jump through the button hoops and forget what you called for in the first place.
-Bill-Bill
On my last 788 saw (3 of 3 since Nov) the pivot screw was a little tight and held up the arm until I moved it down which precluded the need for an EZ Lift. On #1 saw I purchased and used the EZ lift and it made life much easier than the block of wood I had been using up to that time. Last night I loosened up the arm pivot screw a smidge and put on the EZ Lift. Your choise, six of one - half dozen of the other... PS: Loosening up the pivot screw a bit so the arm moves smoothly to the bottom of its stop still didn't help close the distance between the blade clamps.
Today, 09:46 AM -
Channel: Scroll Saw Puzzles
Today, 09:26 AM -
Project size 6 x 5,5 inches
Video of making trivet
Trivet pattern
Today, 09:08 AM -
Yesterday, 09:54 PM -
by markdavdThis is a case were the publisher can't win.
I personally like the patterns to be printed at the artist's intended size if at all possible. Let me decide to reduce or enlarge. If I don't have the equipment to make a copy at 100%, that's my problem not the publishers. We all have our own...-
Yesterday, 06:13 PM -
