Hi Friends,
I mounted my Dremel 1680 on the 16500 stand it came bundled with. It is perfectly level, blade square, etc, and is doing a good job. Living in an apartment means I've turned my second bedroom into the project room, so the scroll saw and stand are simply on the carpet. I think the scroll saw had less vibration when it sat on a thin rubber mat on my kitchen worktop, but the kitchen's too little to leave it there -- very impractical!
I put carpet padding between the saw and the steel when I mounted it to the stand. Which of the following scenarios might be the best?
1. Leave the saw and stand as they are, sitting on medium-pile regular carpet.
2. Do number 1, except put the stand on a sheet of 3/4" MDF which then is between the stand and the carpet.
3. Build a sturdy workstation out of 3/4" MDF, and bolt the saw on top. The workstation would rest on the carpet.
4. Do number 3, but put a sheet of 3/4" MDF under the entire workstation, again making a layer between station and carpet.
5. Take any of the above and add a bag of sand somewhere -- your suggestions as to location of sand bag very welcome!
Any other advice/suggestions most appreciated! Once the saw is cutting it goes well, but the vibration means sometimes it's hard to see my blade clearly and get it right on the line, which is important for small/intricate cuts where there's little room for error.
Many thanks, friends!
Ann
Ann
