I have seen some of Jeff Zaffinos advanced patterns in catalogs and on his website. It says he uses spiral blades exclusively to do those awesome potraits. My question is can they be done with a regular reverse tooth blade? I'm sure it might take a little more time to do but can it be done? I'm kinda intimidated by the spirals and haven't had much luck with them in regards to cutting where I'm supposed to cut and staying true to the line. Can it be done?
Advanced patterns and reg. blades?
Certainly it can be done. Not much more to say about it. Spiral or straight blades, it's a whole different theory of cutting. If you know how to make the tight turns with flat blades, you can follow any line a spiral can.
Spirals will give you a wider kerf, which can be useful when you don't want a line to be too fine. Flat blades will give you the narrowest kerf, which can be useful when you don't want a line to be too coarse. A Spiral will make a kerf exactly the width of it's minimum entry hole, so you don't have to worry about tadpoles. A spiral blade can't give you an absolutely sharp inside corner, but the radius can be so small that it may not even matter.
I don't use spirals, but I haven't really given them the chance. I need to sit down one night and just try it for more than a few minutes.
Capt Weasel, I just completed Jeff Zaffino's Engine 86. I used 2/0, 28 t.p.i. reverse tooth straight blades. I didn't think it was that difficult once I got into cutting it. I cut all the small ones first then as I cut the larger ones I taped them back in place for more support. I have tried the spiral blades and just don't like them. Have been scrolling for 14 years with the straight blades. Mick.Mick, - Delta P-20
I guess I'm afraid to try something advanced with a spiral cause I'm afraid I'll butcher it up and have some decorative firewood after I've been working on it for a week. I can't keep a straight motion without some wandering and the line ends up looking a little squiggly which might detract from a advanced pattern. I feel more comfortable with straights cause I've been using then for months now and I'm coming along nicely and want to step up to something more challenging.Confuscious says, "The cautious seldom err".
Hi Bob;
How interesting that you like the slightly ragged edges in portraits with spirals. They will certainly do that.
That is a concept that I had never thought would be appealing but that was just my point of view and perhaps more people would prefer that appearance in a finished portrait .
Great tip. Maybe there are more that like it that way than we realize.
Gosh, if I ever get a request to have one made with slightly ragged edges instead of clean cut ones you might turn this old die hard flat blade user into a spiral user yet.
Don't get me wrong, if you look at the moose coatrack in the Spring issue (not sure if it's hit Canada yet), I used straight blades to cut the moose and tree silhouette--that needed straight lines. But I've started several of Kevin's portrait patterns and finished a Gary Browning portrait, and the jagged edges left by the sprials just softens the edge enough to give is a real shadowed feel--almost like the shading techniques tattoo artists use--the ragged lines soften the hard lines of the design--with a few mistakes, I can make the portrait look even more 3D <grin>
Kool, . . or is that . . Cool
Great tip
Thanks .
I posted a few pics earlier in the gallery under my user id and one is a bobcat that is a great "learn to turn" pattern. It has a lot of squiggly lines and tight corners that are great practice but when you wander off the line it still looks pretty good (I messed up several times). Look for patterns like that to learn with so it isn't so frustrating when you wander off the pattern.-Andy
It's a matter of personal choice...I use flat blades unless the pattern exceeds the throat of my saw (which hasn't happened since I moved up to a 30" throat). Some folks can cut faster with spirals than flats, I average 50 - 75 cuts an hour with flats and I'm able to charge sufficiently at this rate for my work so I haven't really had the need for spirals.
Hey Bob....what do you mean you "started" several of my patterns???? Give up already?LOLOLOL. Well, I never said they were easy.
KevinKevin
Scrollsaw Patterns Online
Spiral blades.
I have posted on this subject before, sorry if I repeat myself.
Try some of the "New Spiral" blades from Mike (flying Dutchman) they are very controlable. I also still feel that the front to back mechanical action of the saw that you are using has a dramatic impact on how easily you can cut with spirals. The more vertical the motion on all axis the better.
In my Humble opinion.Rolf
Oh man...whatever you do, don't tell my wife you're working on stuff for yours Bob.I told her she's on the family waiting list of 5 years for the stuff she wants (she does confiscate a piece every now and then though, LOL).
KevinKevin
Reply to Visitor questionby Bill WilsonDirty & cluttered have been co-mingling in my shop for so long, I can't tell the difference. 😁...
Today, 04:26 PM -
Reply to What is it?by Jim McDonaldFour partially drilled holes in a block of maybe oak?
Got to remember, I am pretty simplistic.-
Today, 01:57 PM -
Reply to Sue Mey's siteby theframerThanks for the advice Linda, I may have to do that. The future bride and groom are avid golfers so I would like to do something special for them. Also I am Godfather to the bride and I'm very humbled that she asked me to do this for her.
Rick-
Today, 12:23 PM -
