No saw yet....
Under 500
Well 500 is not too low at all. I know I will get some comments on this
Get the Dewalt.
In Canada the Dewalt is around $699. with a stand.
In the US it is much less. I havent heard any complaints about it.
I use a Delta and a Ryobi, both under $300.
But then again I don't have lots of money,
I only cut for a hobby and enjoyment,
I love to use BC softwood.
and I am CANADIAN
anyone up for a beer?CAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
You can find the DeWalt (which is surely your best buy at that price) for just over $400 including the light and stand. Do a thorough search on the internet and you should find it, deliverable quickly with minimum shipping charge, (which always amazes me cause the darn thing is heavy).
I've used my DeWalt heavily for almost nine years now and have the feeling that I perhaps should buy another because it's bound to wear out sometime, isn't it?
On the other hand, if you're just getting started and want to test whether this is a hobby you will like, you can buy a name brand variable speed scroll saw that takes straight-end blades at your neighborhood store for around $100.
Good luck....and have phun....
Carter
There are some suppliers that carry refurbished DeWalts . Some say that they are better than one off the production line because instead of a quick spot check on maybe one in ten or so they are ones that have been returned for some little problem and then they are thoroughly gone over to make sure it is right to be sent out the second time. Someone here may have a link to where to get a refurbished one at a big saving. The only difference with it apart from looking like an original brand new will be that they have added a 'R' at the end of the serial number.
Good luck.
Fred
Howdy, Twister. I'm new to the hobby myself, and just got my saw. I went with the Dewalt, due mostly to the recommendations of the folks on this board. I haven't gotten a chance to use it much, just a couple of practice runs. Today I finally got to cut out my first pattern, the butterfly from John Nelson's book (also highly recommended).
This gallery has 2 photos.-
Today, 12:13 PM -
Reply to First Project - Stretching Catby Sandy OaksVery well done, especially for your first. I too like the added detail.
Today, 11:22 AM -
by RolfThe end result is beautiful I really like that Hummingbird design....
Today, 09:54 AM -
Reply to Help with spray adhesiveby RolfI have used all sorts of methods for putting on patterns. The only time I put a pattern directly on the wood is on Intarsia as the shaping process removes it. I only use blue tape under the pattern on very small projects.
I Use clear removable contact paper (shelf liner) on the wood and...-
Channel: Beginners Scroll Saw
Today, 09:51 AM -
Reply to Sanding and calibration disk.by RolfI agree about how it was advertised, but it is my own fault, I know better. Just for curiosity I may strip the paint off and see how true the plate is.
The good thing is that while I had my saw blade off I cleaned it sprayed Crud cutter on it let it sit then wiped it off with a skotchbright...-
Today, 09:42 AM -
