Hi I have a Delta SS250 16in. saw and the dust blower is awful . So i hooked up fish tank air pump. i was wonder where i can get some flexiable hose that i can bent in the direction i would like and it would stay where I put it. plain air hose just will not stay where I tape it.
Dust blower tube
Tags: None
Flex hose
There are a couple of things you could use.
The tube from an oil can.
Craft shops have flixable tubing for doll limbs. A friend of mine used one of those for his saw.
One note for this type of airhose, I sometimes find it a bit of a pain when I am cutting a piece with lots of internal holes.
You have to move the hose each time you rethread the blade.
Sometimes I just end up blowing the dust away on the small holes.CAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
DAdams, www.wildwooddesigns.com has a blower kit with the flexible tubing you need for $14.95. Part # T119. I believe Mike at www.mikesworkshop.com has a kit also. Mick.Mick, - Delta P-20
Vacum Not blower
First of all, I get most of my tubing at the local Home Center.
Here is a setup using a small vacuum using a combination of 1/2 inch Schedule 20 PVC pipe for the upper arm and 'old' vacuum hose to a Crevice Took glued to the underside of the table with silicone cement.+Attached Files
Dust blower tube
Thanks to everyone that replyed to my Question on this site you all have helped me local a dust blower tube for my scroll saw thanks alot for the help.sigpicDeb Adams [email protected]
Just from out of the blue, I wonder if having dissatisfaction with the dust blower correlates with running the saw at a very low speed habitually? I've used the Old Delta, Newer Delta, and the DeWalt (my current saw) and I find the dust blower quite adequate when running the saw at at least 1/3 of its maximum speed. Under that, the blower don't blow.
nice setup
Originally posted by bmwbobFirst of all, I get most of my tubing at the local Home Center.
The problem with blowers is they don't get rid of the dust they just move it.CAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
Reply to Bass Puzzleby Scruffy DogI like it! Very Nice!
Channel: Scroll Saw Puzzles
Today, 07:39 AM -
by cwmageeAs far worthiness, I purchaseed the PEGAS table (for my 8+ year old EX21) frrom Denny a couple of years ago. It was well worth the cost as it changed the performace dynamiics. My EX21 had a severe vibration when running the saw above 80% of the speed range, The PEGAS Mod table damped the vibration....
Today, 07:26 AM -
Reply to Mothers day flowersby NC ScrollerRolf they look great. Thanks to your club for the wonderful donation.
Today, 05:31 AM -
by Scruffy DogThis is a Steve Good pattern finished today. First one this year in fact. Pine with amber shellac. It's going to work tomorrow to sit on top of my computer. What do you think? ...
Channel: Works in Process
Yesterday, 07:21 PM -
Reply to NWA Showcase 2023 Resultsby NC ScrollerCongratulations!!! An honor well deserved.
Yesterday, 04:21 PM -
