dust bags
  • dust bags
    Hi can any one tell me if those bags that mount under scroll saw tables or the stand doing any good and catching the dust from the saw?
    "A woman is like a tea Bag------- You can't tell how strong she is until you put her in hot water."
    sigpicDeb Adams [email protected]
    The dust on the scroll saw is very fine, just like sanding dust. The bag would collect some but I really recommend using a vacuum. It keeps the saw clean as well as the surrounding area.
    • Sandy Oaks
      Teach - Learn
      by Sandy Oaks
      This gallery has 2 photos.
      Today, 12:13 PM
    • Sandy Oaks
      by Sandy Oaks
      Today, 11:22 AM
      Today, 09:54 AM
      Today, 09:51 AM
      Today, 09:42 AM
