WHAT TO EXPECT FROM DRILL POWER VS. STD. MOTOR US
Re: WHAT TO EXPECT FROM DRILL POWER VS. STD. MOTOR
I think I'd stick with the Dremel for carving & use the drill for drilling. Dremel also sells one or two shapes of kutzall burrs as well as two sizes of drum sanders on the 1/8' shank & the prices aren't that bad either. Pineyknot
You can make a decoy using hand tools for the roughing out.
A drill can be used with a drum type sander to smooth your carving. It is underpowered, but better than working by hand. I used a drill before acquiring a Woodhog carver that will use 1/4 inch shaft rasps and sanding drums.
A friend of mine likes to use a die grinder from Sears. They are about 99.00. They accept the quarter inch shafts and have a higher rpm than a drill.
A good carver can do more with inadequate tools than bad carver can do with top of the line.
I stsrted with a Dremel with their flex shaft four years ago. I was able to do almost anything you could want to with it. You will find the drum sanders the most useful. I recomend you clean the spring shaft and coate it with a thin coat of STP, STP is made for high rpm's and high heat, it want pack down to the handpice and dry out like grease. I did that with mine four years ago, now I check it once a year and if needed I re-do the STP.
Channel: Welcome Members
Yesterday, 08:08 PM -
Yesterday, 07:56 PM -
Yesterday, 05:38 PM -
Yesterday, 05:09 PM -
Yesterday, 04:51 PM -
