How to identify the model # of an old Delta saw?
  • How to identify the model # of an old Delta saw?
    Hi folks,
    I'm new to the forum. I have an old Delta Milwaukee Scroll Saw, 24 inch, that I believe is from the early 1950's. The serial number is 104-6693. It looks like a series 40 when I compare looks and part numbers on the Delta PM 1512 Operating and Maintenance Instructions.
    How can I tell the actual Model number?
    Thanks!
    The easiest way would be to post a couple of pictures and I'm sure somebody here will know what model it is.
    Tim
      scroll saw pics
      hope I got this correct.
        Most of the time, manufactures put the model number on the same plate that has the serial number on it. The plate is on the top of the motor in your pictures.
        george
        George
        delta 650, hawk G426
          Hi ship4u - take a look at this page link.
          http://bridgeport.askmisterscience.com/1962-1.gif
          This looks to be your saw except that it includes the optional accessories. Curiously enough the motor is listed as an accessory!
          Hope this helps
          Jim in Mexico
          - Albert Einstein
            Thanks for the link and the help!
              Today, 08:57 AM
            • Dan A
              by Dan A
              Today, 06:33 AM
              Reply to Another Celtic cross
              Yesterday, 09:47 PM
            • Harry
              Reply to Toy jeeps
              by Harry
              Hi Jim.
              sure you...
              Yesterday, 01:18 PM
            • jim_mex
              Reply to Toy jeeps
              by jim_mex
              Yesterday, 10:15 AM
